on my speedway car we run a rear radiator so i have a custom installation.
now taking comments from other sections people etc and a down fall of no1 on a 6 is it is the coldest cyl while 6 is hottest.
now on a 250 if you made a plate up over the water pump which strengthens the block a bit.
then install all the welsh plugs in the block drilled say 1/2in hool in all 6 along the left side of the block welded a 1/2in pipe out that connects the 3 rear together and the 3 front together but in seperte pipes to keep feed and pressure constant and have join at 1 pipe with an electric water pump.
to my way of thinking this whould feed every cyl water with in 5deg of each other.
whats your oppion
or whould i be better off reversing the flow of the system o have it draw through the head and out the block.
whats your oppion
