It's been a while since I posted. I've had my car on the road all summer and it runs well - plenty of power, but it needs a bit more. I've got it winterized now, back in the barn on jack stands and I have a few months while the snow blows.
A planned upgrade for this winter is to fuel inject it and get around the log intake problem - I've found a spare head so I can do some experimenting. The plan is as follows: Use standard commercial plumbing components to build a triple intake - a 2-1/2" main intake plenum in parallel with the log intake; 3 -1.5" tees coming off the plenum and entering the log between 1-2, 3-4, and 5-6 cylinders, using ANSI copper flange fittings. A fuel injector at each tee - I can probably use 1.5" - 1"tees between the plenum and log and epoxy the bungs into the intake in this manner. I'll need to cut two holes into the log on either end, but I can do that with my drill press and a good hole saw; use a good ceramic epoxy to get a good fit between the flange fitting and the log - there seems to be enough material in the log to drill and tap some studs into place to anchor the flanges. I haven't decided whether to solder the fittings together or epoxy them - I think either will work fine. A 50-55mm throttle body from a modern 6cyl engine is well sized for this application - they're a dime a dozen at a junkyard. The fittings and pipe will run me about $200, which isn't cheap, but there's no machining, furnace brazing or custom welding involved and since the fittings are pre-made and socketed, it should be relatively easy to fabricate and make airtight. Essentially, this is an electronic version of the Offy Triple Intake, and should render similar results.
Thoughts???
Thoughts???
