Howdy Bck
A remanufactured head will, most likely, have been milled to true the mating surface. How Much? At least .010", maybe more.
Measuring the volume of each chamber, in cubic centmeters is the only way to know, and then use that dimension to figure the ture compression ratio. Adam posted the "How to" link from Doug's home page.
On a late model, 62 cc chamber head, a formula for estimating chamber volume reduction is 2 ccs = .010". Estimating and measuring are not the same. It is best to measure.
If you measure the volume of each chamber you will likely find considerable variances. FoMoCo quality control was less than ideal on these casting. It is a good idea to know the smallest for figuring CR. It is best to even the chamber volumes up to within one cc.
What head gasket will you be using?
Once you have the dimensions you might want to go to our web site. It is in my signature. Click on the compression calculator, plug in your numbers to get your new CR.
