crackin open the 250
250mav
when i got my maverick there was already a big dent in the front of the pan. it was never a problem but recently i havent ben able to seal the drain plug. i think its a combination of a crease from the dent leading right to the drain hole which is probably a small crack originating off the drian hole. so if the hole isnt slightly spraded apart from a crack there probably is some stripping involved too. ive tried rubber washers on the plug which used to work but that dent's crease dosnt allow a flat surfac for it to seal.
anyway i read my old chiltons maverick guide on I6 oil pans. looks like you just un-bolt it and bolt the new one back up. i was wondering if the timing cover would have to be losened but it didnt mention anything. but when i read how to change the timing cover it instructs you to drop the pan. but since im leaving the cover it shouldnt be an issue.
so while im up in there what else should i get into. figure it's a good time to hang a new oil pump. 32 years of pushing is a long time. I havent had any reason to belive thre to be an issue but should i do the rod bearings and bolts.
so what would be a good place to get a pan? the chrome JC Whitney valve cover fit like crap and as much as i'd like a chrome pan it definatly wont be their cheap china crap. classicinlins.com has a nice one but $300+ seem a little too much. can i just walk into a napa and order one? finish is not important, i'll just paint it blue if its not chrome:)
i cant find any oil pumps on classic inlines. after that napa fule pump cracked in half on me after a year im not sure i want to trust the oil pump. any other high quality "normal" use options out there? probably donr need a HV for a cruiser?
it looks like they will have the hook up on ARP bolts if i decide to go that far. rod bolts=$60 main bolts=$110 seems a little excesive for something thats not getting a full rebuild but i know im gonna regret it when i break a rod off the crank. isnt that how it always is?:( they have clevite main bearings($85) and rods($45) but i could probably order it all through my uncle's napa employee discount for a little less.
feel free to voice any opinions on the matter
