Does anyone know the standard tolerances for the main and big-end crank journals on a 1969 250cid?
I managed to find these specs in an old post:
Main bearing journals:2.2482" - 2.2490", out of round limit 0.0006"
Main journal run out limit:0.002" max
Main journal run out service limit:0.005"
Main Bearing thrust face run out limit:0.001" max
Rod bearing journals:2.1232" - 2.1240", out of round limit 0.0006"
And also
Main journal 2.3982"-2.3990"
I think the 250 has larger diameter mains, so is the latter the size of 250 main journals?
cheers
Rob O.
And also
cheers
Rob O.
