Does10s":2b49yd78 said:
Looks to me if you're at 130* and 10* then you're intake centerline is at 120*.
This is incorrect. You are trying to use both methods (@50 and Centerline) to degree the cam. You can't do that.
When using the @50 method, you do not subtract one number from the other to calculate lobe center. Even if you did, you would be assuming that the lobe was symmetrical, with its opening side being the exact same shape and size as the closing side of the lobe. Truth is, most lobes are asymmetrical, with the opening side of the lobe being much more aggressive and the closing side being more gentle. When using the @50 method, you must use the valve events to degree the cam, not an assumed centerline.
If he got those readings using the centerline method, then he is obvously doing something wrong. If you add 130+10 and divide by 2, it yields a lobe centerline of 70 degrees, which is impossible. If using the @50 method, he's saying the intake is opening 50 degrees BTDC, and closing 10 degress ATDC, again impossible. Either way, he's doing something wrong. More than likely the degree wheel is set improperly.
I'm not sure why everyone thinks the cam cards are not user friendly. It has everything you need to degree the cam, using either method.
If you are degreeing using the centerline method, and advancing a 264/110 the recommended 4 degrees, the centerline should be set at 106 (110-4=106). If the lobe center was 112, you would degree the cam to 108 (112-4=108).
If using the @50 method, you use the valve event numbers. The 264-110 cam card shows the intake opening at 22 degrees BTDC @50, and closings at 62 degrees ATDC @50. Using a 180 degree wheel, the pointer should read 158 (180-22=158) when the intake opens, and 62 when it closes. You can confirm the centerline or lobe center as well, 158+62=220 /2=110. However if you advance it 4 degrees, it would be 154 and 58 respectfuly (154+58=212 /2=106).
It also sounds like he is doing this using a hydraulic lifter, which is a definite NO-NO. You MUST use a solid lifter. Yes this means pulling the head, unless of course you have a solid lifter cam, which he does not.
If he's taking the dial measurements off the valve stem, or retainer (recommended), he must also make sure the indicator is parrallel to the valve stem, otherwise the reading will be incorrect. Also if using non-adjustable rockers, you need to use an adjustable pushrod, with the solid lifter.
Some people like the @50 method. While others prefer using the centerline method (off the retainer) as it takes pushrod and rocker deflection into account. It is generally easier to understand and do, with less chances of making an error.
fphillips":2b49yd78 said:
Mike, can we please get more explicit info from Clay Smith on the cards? The valve event timing is pretty useless without knowing what lift they're measuring at.
I'm pretty sure it's @50, but I will call Clay Smith and confirm it.
