So using clay smith dial indicator, degree wheel and new custom ground cam. I came up with 93 lobe center when the sprockets were dot aligned. Did it multiple times with the same result. Then I moved the sprocket/chain one tooth offsetting dots as pictured below and came up with 111 center lope when it’s suppose to be 110. Anyone else experience having to off set dots in order to achieve straight up lope center? My ultimate goal is 105 intake
