BaldEagleMav
Active member
Hi,
I am thinking that I blew another head gasket.
Some history: When I bought my '73 Maverick with the 250 I-6 and C4, it had a couple of problems. Among them, oil in the cooling system. The symptom of this was a dark brown scummy layer floating on top of the water in the radiator. I removed the scum a couple of times as well as I could, but the oil slick came back again everytime.
I wanted to hop up the motor anyway, so I ended up buying a head off a '78 Fairmont with a 200. (I grabbed the DSII dizzy and module off the same car). I had the head checked out at a local machine shop. The valves didn't leak and there were no cracks in the head. I had a port divider welded in and then had the exhaust manifold surface milled flat in addition to having about 0.010" milled off the head to ensure a flat surface. I installed the head with a Felpro composite gasket, along with a Clifford single-out header. I used hardened washers under the head bolt heads and torqued the head bolts according to the recommendations on this forum (including letting the first torque-down increment set overnight). With a rebuilt H-W 5200 from Tom Langdon, I was very happy with the performance of my mild hop-up. I constantly checked the cooling system for any signs of oil for over a year (not much mileage - maybe 2500 - 3000 miles).
This last weekend, I pulled the radiator cap and found a small(?) amount of scum again! To give you an idea of how much, the entire surface of the radiator opening is full (at least) and it's about 1/2" thick.
I am guessing the head gasket went bad (again), since this is not the same head that originally had the problem when I bought the car - and the fact that the engine went a couple thousand miles before the problem reappeared.
Any ideas on what (if anything) I did wrong? Any suggestions on how to ensure this doesn't happen again? Would retorquing the head bolts periodically help or hurt?
Thanks for any suggestions you may have. I enjoy reading everyone's posts and responses, and my Maverick has benefitted in many ways!
Regards!
Regards!
