Has anyone done any homework or working experience on the 2 different water pump impellers which come on reman water pumps??
There are the cast impellers with a cast backing or mounting surface for the impeller blades.
Then there are the stamped steel impellers with no backing just open blades.
I know years ago a company offered a sheet metal circular plate for the various manufacturers that pop rivited onto the open impellers & were supposed to increase flow 25%.
Just wondered if anyone has some direct experience with both type of impeller designs as far as flow & cooling ability.
http://go.jeep-xj.info/HowtoWaterpump.htm
http://www.flowkooler.com/
This is just an example. Bill
