Well, In the last 2 days, I have had 2 dizzy's fail. The gear has been eaten up and now the cam has broken teeth as well. I am at a loss as to what happened. At first, I thought it was a faulty rebuild, but the same thing happened to the second one in 36 hours. The shaft appears to be pushed back up into the housing of the dizzy as well. They were rebuilt DII's, the car ran fine when it was installed and the first one ran for almost a years worth of running, probably 2000 miles, the second one lasted as I said maybe 50 miles. It looks like the comet is down until I can pull evrything out and check it out again. The first time I drained all the oil and pulled the pan and flushed it out. I have to say, I did not pull the cam and check, but I probably should have. The teeth I could see, were OK. Any suggestions as to what and why?
