Hi Guys,
I have a 68 Mustang 6 cylinder 200, I put this basket case together two years ago. Since then I’ve only gotten 16 mpg so I decided to start checking things. What I found is the distributor centrifugal advance works fine but when I hook the vacuum line to the distributor there is no further advance. I am holding the rpm between 1500 and 2000 when I am checking this. I have put vacuum gage on the distributor line and found it to be only 5-6 inches of vacuum at this rpm. What is going on, why won’t this advance further? Some other people said it was the SCV carburetor. Is there any way to correct this? I know the exhaust manifold does not have a heat port and was designed for a hand choke. I have converted to an electric choke.
Thanks,
Fred
http://i532.photobucket.com/albums/ee32 ... C01745.jpg
http://i532.photobucket.com/albums/ee32 ... 1252243509
Thanks,
Fred
