Rebuilding 1978 200 ci - 1965 mustang
A month or so ago I posted a pic of a carter YF carb and asked for help in determining what the ports were meant for. Since then, I have found a pic I took of the engine before I removed the carb and distributor, and the pic shows the hose routed from the distr advance to a carb port which I understand is the venturi vacuum for the later (dual advance) distributors. Heres the two pics side by side as one image. Pic #2 from june 2005 shows the advance hose routed to a lower port on left side of carb. Pic #1 is a pic I posted a month ago and it was suggested by CZLN6 that I run the distr vacuum advance hose to the carb port on the right side, near the top as shown by arrow.
Question #1 Did the previous owner simply have the vacuum hooked up wrong? Btw, the old dizzy was a loadamatic.... new dizzy Im hooking up is DS II, single advance. I will go with CZLN6's advice but just curious about the previous owner's hookup. Also, What the best way to plug an unused vacuum port?
Question #2 Altenator is 65amp. What would be a good battery match for that?
