Okay, I've talked enough about doing it! So, this weekend...I am going to TRY and divide the "log" on my '78 200 into seperate plenum chambers - two to be exact.
My thinking is this...(because I cannot weld)
Block off the existing single valve carburetor opening. Drill and tap the block off plate to accept a 5/8" or 3/4" dia. bolt (s.s. of course). Fasten the bolt to the plate so that the bolt threads set inside of the "log". This will divide the log intake into two intake plenums but allowing enough balance for proper vacuum distribution.
Will this work?
-Chris
Will this work?
-Chris
