sivadmatt99
Active member
the one i have is .452 that is close. i didn't know the shaft could be turned down.wsa111":25pn5d16 said:Thanks 5/16" shaft size.
To repeat I have a Duraspark shaft with 5/16" oil pump drive. The shaft has been turned down to .465" in diameter.
Is that the diameter of the original 1/4" distributor??
If that is correct all one would have to do is install a later oil pump for the larger shaft, but the shaft diameter would fit the earlier block.
Advise, Bill
