mustangman33
I'm putting on the bellhousing to my 200 performance build (about 9:5 compression ratio) and the high performance starter I ordered from summit does not fit (god forbid any part that I order online actually does).
As far as I know powermaster is the only high performance company that would have the right application (if they even do, since the one summit sent me from them for my engine does not). I'm wondering if it would be ok for me to go to the local auto parts store and pick up an oem starter because it will be much quicker that ordering anything online. I'm just wondering if the oem will be enough for my build. Part number for the powermaster i received: http://www.summitracing.com/parts/pwm-3 ... el/mustang. Also, i'm doing the t5 conversion with a 66 bellhousing and block plate - so 2 bolt alternator (although for some strange reason, half of the parts store i call say the starter they have for my motor has three bolts).
Thanks in advance.
As far as I know powermaster is the only high performance company that would have the right application (if they even do, since the one summit sent me from them for my engine does not). I'm wondering if it would be ok for me to go to the local auto parts store and pick up an oem starter because it will be much quicker that ordering anything online. I'm just wondering if the oem will be enough for my build. Part number for the powermaster i received: http://www.summitracing.com/parts/pwm-3 ... el/mustang. Also, i'm doing the t5 conversion with a 66 bellhousing and block plate - so 2 bolt alternator (although for some strange reason, half of the parts store i call say the starter they have for my motor has three bolts).Thanks in advance.
