DOHC 300 Head
4000 FPM average piston speed is the limting number I have always heard for reducing catastrophic failures.
For various Ford engines:
200 - 7678 RPM
240 - 7545 RPM
250 - 6138 RPM
300 - 6030 RPM
302 - 8000 RPM
351 - 6857 RPM
460 - 6234 RPM
4.6 - 6773 RPM
5.4 - 5762 RPM
Long rods help reduce piston acceleration and decceleration at TDC and BDC effectively reducing inertial loading. It also helps to keep reciprocating mass to a minimum.
Piston speed is still the same but these two factors help tremendously.
The thing that blows my mind is the fact that @ 7000rpm the valves open and close 58.3 times per second and for over half of that second they are setting still :shock: When you think about it valve springs are pretty amazing, yet mostly taken for granted.
eh, for the supra guy. this is a 300 inch motor we speak of, its alot more than just 3.0 liters. if you could find a way of adapting DOHC and some fuel injection to one of these engines it would be a beast, but the engineering process is murder. not to mention the price. one day we will all hit the lottery and build a ford six that can rev to 8000 rpm and make 600 whp on pump gas. 8)
Four valve big engines have been around a long time. Witness the Rolls Royce Merlin. Something like 21-22 liters? IIRC with a four valve pent roof head.
During bike week in daytona in the early 90s. I saw a motorcycle with a V-twin It had two 4 valve heads cut from a merlin v-12 as far as I could tell.
I can still picture it in my mind. It had on the side of the seat "5000cc"
It also had a small looking 4-71 blower and a Q-jet card at about chin height.
Oh one more thing it had a No2 plate system under the carb.
