Dress up item suggestions need.
65coupei6
Staff member
Well I finally got a bolt kit together for the Oz-250 intake. Hex or Allen head, polished or unpolished. They should also work with the 221sp/me heads.
The polished upper radiator hose will be hopefully done next week then I can test fit.
Adjustable stainless steel export and monte carlo bars are still being worked on.
Do you guys have suggestions for more items to dress up our inlines?
I know Mike has looked into valve covers and so have I. But my prices seem to be in the $150 range. Any takers?
I am also thinking of doing a billet aluminum spark plug wire loom. Probably in the $40-$50 range.
A stainless fan shroud would be nice.
Stainless MC caps
Stainless Voltage Regulator covers
How about some stailess t-bolts to hold the export brace in place.
Stainless shock mounts
a nice cover for the fan motor
aluminum fan pulley
alternator brackets (I think someone was workin on that)
I'll think of more stuff later......
"ask and ye shall recieve"
i remember seeing that someone had once made chrome plates that bolted on over the edges of the engine bay (where the fender bolts to the inner walls of the engine bay), and over the radiator support, that could be cool
chrome master cylinder cover. cchrome power steering pump cap chrome pulleys. there are lots more
I would still give my wallet for a pair of NICE custom fender badges...
GT200
incorporate I6 in there and you have a winner....
I remember someone working on them, but never heard anything?
make sure you have a "dressed down" Babe next to the car when taking pictures....
As far as a valve cover, you can get a plain chrome valve cover for about $40 (NAPD)
i WOULD LIKE A CROME WATER NECK, AND IN ONE OF THOSE PICTURES OF SOMEONES CAR THEY HAD A BRASS TOPPED RADIATOR I THINK THATS AWESOME BUT IT WOULD BE EVEN COOLER IF IT WAS A CROME ON MY APPLICATION I THINK, BUT ON HIS I THINK IT LOOKS HOT. MAYBE A CROME INTAKE FOR THOSE 2V/250 HEADS OF MIKES, AN ENITRE BLOCK WOULD BE TOLDLY BACK DOOR. IN THE FUTURE I PLAN ON BUILDING UP A TOLDLY STOCK MOTOR SO I THINK A EXHUAST MANIFOLD THATS CROME WOULD BE COOL BUT I AM NOT SURE IF YOU WILL GET ANY TAKERS. I KNOW THIS IS PROBLY REALY HARD BUT A IGNITION BOX, OR COVER WOULD BE COOL CAUSE ON MY CAR THE RED MSD IGNITION BOX REALY STICKS OUT. SOMETHING COOL I EVEN THINK YOU WOULD GET SOME V8 OWNERS TO BID ON WOULD BE THE WIRE COVER HOSE STUFF IN A CROME OR ANYTHING SHINEY NOT BLACK, RED OR BLUE. TIMEING CHAIN COVOR, FUEL PUMP, FUEL PUMP BACKING PLATE, WATER PUMP, AND A ENTIRE CROME BOLT KIT LIKE THOSE ' ARP RACING' ONES YOU GET FOR V8'S.
HOPE SOME OF THIS YOU CAN GET, ALSO EVERYONE I HAVE SOME SHOCKING/SAD NEWS TO REPORT LOOK UNDER THE TOPIC SHOCKING NEWS.
I've got a little chrome on mine...check out the wire looms I made for $10, chrome oil and breather caps, crhome ignitor II, I suppose I could polish up and buff the oil sending unit...sometimes too much chrome means too much work for a daily driver...so the chrome I have is easy to get to with a rag.
Thanks for the replies.
I know I will start work on some billet water pump pulleys, water necks (if Mike hasn't already), aluminum valve covers (again, if Mike has not already), billet wire loom, and stainless regulator cover.
You guys can check out http://shop.mustangindex.com for the stuff that I already have.
I'd take a stainless regulator cover!
Also,
How about a stainless cover that goes over the vacuum advance on the distributor? I think Mr Gasket or someone used to make em....They were polished and had a hole in the ceter for the advance hose and they were held on with a piece of 2 sided tape.
Later,
Doug
here's what i was talking about
it can be found here
