I've finally caught the bugger dripping fuel. I ran the engine for 10 minutes at idle and then shut if off. The engine was not up to full temp yet but after waiting a good 5 minutes it started to drip out of the venturi above the throttle plate. Obviously this leaves a bad fuel smell and results in a flooded condition.
Besides readjusting the float lower and inspecting the needle valve and seat is there anything else? Just how low should I go with this. It's currently set even with the top of the float bowl per the Motor Manual for California. The other 49 states are set a bit lower, I don't remember how much.
It's a 82 with the 1946 holley.
