DSII coil resistance
JackFish
2K+
I think I have a bad coil and am looking for testing info.
It's off the car and if I measure the resistance between the center cap and the other poles I get a reading of about 8.9KΩ.
Is that way off?
ok, you have 2 sets of windings in the coil, primary and secondary. the secondary is where the coil wire plugs in, to go to the distributor, and the primary, which is run between the pos and neg terminals. you should be very close to OL measuing from the secondary winding to the primary winding. so 8 kilo OHM, is probably a shorted out coil.
It's been really cold here, and I seem to have experienced a plethora of problems that cropped up at the same time.
First was the stalling every two blocks or on turns, stops and bumps.
So initially battery was suspect but that turned out OK because I have spares and a booster box.
I knew the carb has some stripped screws and so I swapped that out. There WAS a piece of small wire stuck in the inlet valve. And a small ding in the fuel filter so I think it may have been a little piece of mesh.
So it ran for a bit, really well at one point, but began to refuse to keep running and started stuttering. I suspected fuel pump, swapped that, no joy. Finally no spark today at the coil. I have swapped out the alternator also. (thanks Norm! :D ) It cranks over really well. I also have a spare regulator to test with as well.
I've been going over the wiring and swapped out a crappy battery lead.
The distributor is clean and dry.
I just got back from the parts store with the new coil and took a couple readings. I discovered there should be continuity between the + and - posts, right? I then checked the dirty old coil and there was intermittence. I will clean everything, and the harness, and if I'm lucky I'll get to return the coil. And Norm's alternator. :wink:
I just checked a known good DS2 coil and it showed 6.3K ohms between the high-voltage terminal and the primary terminals. It also reads 1.6 ohms between the two primary terminals.
Joe
I just checked this new one as well and the resistance seems a little higher at 8.5 and 2.4.
I believe now it is the coil because the old one won't keep a steady reading, ohmage jumps all over the place.
I'm having the EXACT same problems, and the funny part is, I went "Check the carb, fixed wirings to the coil, checked the battery, checked the distributor", but haven't checked the coil yet. I have another known good coil off of another engine that I pulled awhile ago. I HOPE that that's my problem. I can swap out the coil in about 30 seconds. I was having problems getting it to kick over, then it would stall. It would run badly, then run good, then run badly. It would stall when I stopped. I was getting bad spark. Sound like a coil issue?
