DUI Adjustable Vacuum Can Allen Key Size?
'68falconohio
Do the DUIs have an adjustable vacuum can?
If so, does anyone knwo the size of the allen key that's hiding in there?
I want my vac. advance to come in at a different rate/little later. Vacuum can is connected to ported vacuum.
Thanks,
Stephen
Thanks,
There are no flats around the small diameter. I tried 7/64" and sized down from there since it was the largest that would fit in the vacuum port. I couldn't feel any sort of screw in the can but wanted to check on here to make sure I wasn't missing it.
Looks like I'm buying an adjustable vac advance can.
fphillips,
I'm assuming a replacement for a GM HEI distributor will work?
Yes , the crane cams unit was the best deal if you can still get it as it cam with a limiter , and some springs too part number proform seems to have the best deal , its on summits site for 16.95
