DUI dist. question
yodabiri
I am wondering about the new dui distributor. What i am wondering is if i will be able to use my current autolite 1100 carburetor with the scv and run the DUI? Will the scv interfere? I know you can run a better distributor with the same carb but not a different carb with the loadodizzy. Also if i get a distributor curved for an engine with a holley 350cfm, and headers, and manual trans, will that have any adverse effects on the performance of the car because i have not added those parts yet, but plan to in the near future and just want to deal with the ignition right now. Sorry for the long question i hope you can answer...
Thank you in advance!
Read this topic, recently posted and still active.
http://fordsix.com/forum/viewtopic.php?p=256128#256128
Running a DUI on a fairly stock '66 200 cu in. It has a header, port divider, mild port job, Autolite spark plugs and a slightly used Pony Carb Autolite 1100. And it flippin' runs great!!!
The DUI is the best cure for Load-o-matic faulty SCV valve!
I couldn't find the used parts I needed for DS, so only a few bucks more I got the DUI as compared to what I would spend for new DS stuff plus a MSD-6. It installed in minutes; a single wire is all it took!
Thank you for the reference! I am looking foreward to buying the distributor in the next month or so!
Thank you!
