okay, shopping through some old posts before buying an electric fuel pump. my problem is only 4 psi of pressure (at idle) from the mechanical, even though it's brand new, and the car runs awesome until i open it up, then it runs out of fuel in seconds. so, if i just want a couple pounds of boost to the regular fuel pump, and for more fuel flow when i need it, sounds like the cheapest and safest option is one of these diaphragm pumps from facet or SU? is everyone out there using an electric pump removing the stock mechanical pump, or are some of y'all boosting with electric?
by the way, it's not the choke flap slamming shut, the vacuum goes to zero when i go WOT, last year i got some good advice that said it's likely fuel supply, bowl going dry to soon. raised the float level, little or no change.
thanks....
