66 E100 Pickup
Hi all, I am proceeding with my duraspark conversion on my '69 200 six.
I have read the stickies several times, but I need to revisit the issue of voltage supply to the "+" side of the coil as there seemed to be a lose end on the issue.
Let me recap according to my understanding:
1) the stock duraspark ignition coil, as connected correctly, gets a full 12 volts during cranking, and 6-7 volts during normal run mode;
2) the full 12 volts will retard the timing to allow for easier engine cranking;
3) 6-7 volts will keep the ignition coil from overheating and shortening it's life expectancy;
4) The 6-7 volts is achieved by bringing in a 12 volt line upstream of the fat pink resistor wire (some 60" long) that connects near the ignition switch
Now my question--is anybody running 12 volts continually to the stock coil, with what results? What about 12 volts continually to a perfomance aftermarket coil such as a Jacobs, etc., anyone run into issues?
Does the 12 volt vs 6-7 volts have any effect on the module life expectancy?
Thanks,
John
Thanks,
John
