barishiman
hey everybody, long time now see!
for xmas this year I got a MSD ignition box to help me out with the duraspark II conversion in my 1965 mustang and for the past couple of days I've been trying to get the car running but have failed at every attempt. Therefore I consult the board.
Here's my setup
1965 mustang w/ I6 200
Weber 2bl carb
MSD 6A ignition box
Pertronix flame thrower 2 coil
Painless performance chassis wiring kit
remanufactored dizzy for 1979 Ford Fairmont
new rotor and cap
spark plugs set to .050 gap
new spark plug wires - 8.0mm crimped myself
new ignition switch
new solenoid
Problem
This fall and winter I've been rewiring the whole car with plans to have the engine run again before spring. I've followed Painless performance's wiring diagram concerning the installation of an MSD ignition box, MSD's instruction on Duraspark installation and followed the guidelines specified on Classic Inlines regarding installation of the Duraspark II conversion. When I changed out the dizzys, I made sure the new rotor lined up in the same position as its former. I proceeded to check for power - all good - and began to crank the engine with at least 5 gallons of gasoline in the tank. The engine will turn over and fire but will not run. Before the rewiring/ignition change the car would start and run fine.
I've rechecked the dizzy installation making sure the rotor faces in the #1 firing position with the #1 piston @ TDC after the compression stroke - based on the maintenance manual. I suspect the car wouldn't fire if I had the dizzy installed on the exhaust stroke. I then checked the ohms for each spark plug wire and here are my findings.
wire ohms length (in)
coil 8.3 17.5
1 7.5 17.5
2 8.0 16
3 7.5 18 1/4
4 5.5 20 1/2
5 13.2 30 1/2
6 13.3 33
I suspect that the #5 & #6 wires could be a problem due their higher ohms, so I changed out the #5 plug wire to a used 8.0mm that had a lower ohm number, still the results are the same - car will fire but not run. I have also switched out coils and no change. Both coils are reading approximately 2.0 ohms. Have recharged the battery every night after too many starts.
The chassis wiring kit did not come with a resistor, and the instructional manual fails to include two wires that are labeled 1) from fuse block to ignition module 2) from fuse block to ignition coil/resistor - these wires are not mentioned either for the MSD ignition. Since the car is firing I doubt this is the problem.
Are there any tests or procedures you guys can suggest? Its been fun working on the old car again, but this problem has me stumped.
Here's my setup
Weber 2bl carb
MSD 6A ignition box
new rotor and cap
new ignition switch
new solenoid
Problem
coil 8.3 17.5
1 7.5 17.5
2 8.0 16
3 7.5 18 1/4
4 5.5 20 1/2
5 13.2 30 1/2
6 13.3 33
