I have a stock 144 that i adapted a duraspark distributor to. I am running power brakes off of the manifold vac. port through the 2 stage fuel pump. also i am running wipers off of the same tap. I plugged the old vac. tap on the carb. and am drawing my dist. vac off of the vac. tap at the bottom of the carb. I rebuilt the carb in the same proccess. I have not set the timing yet except by ear. when i blip the throttle the engin hesitates just like the accelerator pump does not work.
Here is my questions; 1. did i tap my vac for the distributor from the right spot? 2. do I set initial timing with or without the vac line hooked up? 3. what do you guys reccommend for initial timing?
Thanks in advance for any opinions/ advice anyone can give me
