Duraspark wuestion
Ba Mustang
I am in the process of doing the DSII swap. The CI instructions are confusing. I have cut the pink wire and the brown wire. Where do I get the 12V source? It just find one or splice it in. Which wire on a 67 mustang ignition is getting 12v when the switch is on run?
Ok I have the brown wire clipped off of I post. Module wired to S post, Pink wire clipped, and 12v source from green/red wire on ignition. It cranks but won't start. I am using my original coil if that matters. All wires wired correctly.
Finally got it running. Coil we had on was shot. So I went and got a Blaster 2 Coil.
I don't ever want to do this swap again unless I have atleast a week off. Was rushed to get it finished and wiring doesn't look too great.
