? Duraspark2 wiring
TNT
ok the wiring is ez enough but 1 thing that seems odd the red and the white wires coming out of the ignition module are swaped on the other side of the plug the white becomes the red and red becomes the white why is that...............and to make sure that i was'nt wrong i looked at my monarch and the plug is the same white on 1 side and then becomes red on the other,did the wiring diagram on the tech page take this in to acount or should i just follow the red and white from the ignition module and not the colors on the other side of the plug[/url]
come on guys i know someones got to have an idea,i'm sure some of you guys have already done this mod.,did you use the factory plug? or cut it off........when i was at the junkyard i took all the factory plugs and wired it in so if it need to be replaced i could just unplug it and swap as needed......any ideas please Thanks to all
Try plugging it in and see if it works. If not, cut off the plug and hardwire it.
ya will i just wire it as the red was the white and white was the red and all works......to any one that dose this mod. look at the red and white wires on some years there are switched in the plug keep an eye out
