So I've been wanting to supercharge my 300. I've come up with a plan to use a drawthrough setup with the supercharger on an electric clutch via a special valve I've designed to transition from aspiration to boost.
I see a great deal of discussion about mounting the M90 to a 300. has anyone actually done this? I've determined the M90 as supplied in the Thunderbird supercoupe is perfect. It's the early M90 with the 'noisy' ouput port, and both the inlet and outlet are where I need them to mount the blower on the left side of the engine. Fuel will be supplied via my Weber two barrel.
I'll be doing this after I rebuild my bottom end. I already did the top end and ignition. I figure I'll need a forged crank, heavy rods, performance pistons in a suitably low compression range,blueprint, balance, cam, glyptol coat, high volume oil pump and an aftermarket balancer. I also want the piston fuel pump they supply at racepumps.com, but I don't know how much trouble adapting it from the 302 type to the 300 will be. It's inline, not lever operated, so stroke and pushrod depth are the only concerns. 302 has approximately .40 of lift on the eccentric lobe. I can get the electric clutch for the blower from Ogura.
Anyway, words of wisdom as to the M90 and 300 would be appreciated.
Edit for spelling due to smartphone chiclet keyboard.
