OK I have put the carbs on the back burner for the moment: I know I am way ahead of myself but now is a good time to understand some important procedures..
When I close this engine up I will have to start the engine and rev it up to 1500 and 2000 rpm for the first 20 minutes. I understand if I have to shut it down for any reason. I will have to go through priming the oil again.
I will have a new DUI distributor: There is a lot of ""Then"" here so stay wid me..
Q: Can I set initial timing at 14* at the Balancer. Then set the #1 piston on compression cycle to TDC: Then set the rotor to the #1 plug wire. Then hook up vacuum.
Then
Will I be able to start this engine with out problems..?
I plan on blocking the outer 2 carbs with a plate and use my 1v carb to start with along with an electric fuel pump..
If this is a no go procedure, any ideas as to what procedures will give me the best chance at a good engine start.
I'm already concerned about installing the cam. So a good start is needed..
foe some reason my old gun-ho do or die ant what it once was... its mo like woooo wait a minute...wait a minute..
Then
I would also stay from the Snytec type oils until you get some time on the engine so the rings are seated, about 20,000 miles or so.
