Leo
Well how does this look… for starters.
I got my Carb (my new SC Valves),
MPGmustang":21e96522 said:I thought you were going for the alum head, what's this tri-carb setup???
I'm jealous, oh so jealous...
bubba22349":2owosiwr said:I got my Carb (my new SC Valves),
Aren’t you going to use a later distributor? IE like a 68 up points type, a DSII or DUI. If so the 1101 would be better chose and save you some work modding them. In the case that you are keeping the LOD dist. only the center carb needs a hookup the end carbs would be plugged.
I will also be running all 3 carbs as one unit.
I believe these carbs are rated around 180 CFM? So running all three together will allow me to get peak performance at all throttle from idle to WOT..
MPGs is not one of my objectives
whata ya thunk..??? :mrgreen:
