Elect. Fan Opinions Wanted
Just as a visual reference:
Go out and jump start another engine that has a low battery...notice how the engines rpms dropped when the jumper cables where properly attached to the other vehicle? That my friends is the altenator under a load, inturn, increasing a load on the engine. Just for those who say,
" how can a altenator put a load on an engine when it is spinning and charging already?" Just like installing a larger amp altenator, more load is needed to spin it to achieve more amps. It's all has to do with the magnetic field resistance. I think? So as you install more electrical do-dads, the more the charging source needs to work to supply amperage...more gas used, more heat produced, etc... So either way, mech or elec, it all has its pros and cons.
