Ever since I got my Fairmont (8 years ago), it had been plaqued with undercooling problems, especially on hot days. Even changing to a 3-row radiator didn't help very much. It also had disappointing gas mileage for a six.
After examining all kinds of (junkyard ) 200CID radiator fan setups, I decided to replace the thin-bladed 16" Ford flex fan with the setup from an air-conditioned Zephyr. This had a 17" non-flex fan with fat blades and a clutch that spaced the blades 2" from the radiator.
The change was dramatic. Instantly, the temperature was steady and low, even in long traffic tieups with my AC going, and the gas mileage went up over 1MPG (from 16 to over 17 in town).
About a month ago, the clutch started making noises and finally froze up solid (I've never seen one do that before; usually they lose their grip and won't cool). Available power dropped off so much that I could not even drive 70MPH and the gas mileage dropped into the 14's. I went to said junkyard again and nabbed a similar, but deeper, fan clutch from another Fairmont. This one worked OK, but spaced the fan just 3/4" from the radiator. This caused the engine to run VERY cool, too cool, in fact, and the gas mileage was still in the 14's.
So, off to the auto parts stores - finally, after 2 weeks of looking, I found that Ford made a Police Interceptor version of this 200CID six (!) in 1978 and 1979 Zephyrs. The fan clutch for these engines is the short-stemmed one I had stumbled onto in the junkyard. I got one (from NAPA) and installed it: the fan sits 2" from the radiator again. It cools just as well as when I first set it up this way again.
AND- I can run 90MPH, bumping over 18MPG in town, and the available power all through the engine's range is very noticeably better.
Thought I'd pass it along!
