i was pondering whether to mount my 16 derale as pusher or a puller? i believe i have the clearance either way. i am dealing with ungodly rust issues right now, but trying to plan ahead. thanks a lot.
thanks again for the input lagrasta did you use the short or long shaft water pump? i am using the standard 2 two row rad. my measurements could be off... wouldn't be the first time. also, i have not bought the brackets to swap to an alternator from the gen. i may discover i am in a cluster when bolt up time comes thanks again
