Picked up a 215 to make my '52 Panel stock. Went to L.A. on Friday to pick it up.
Got it unloaded...
...and cleaned yesterday. Surprised to see some of the original paint still present.
The engine has been rebuilt once (tag still in place) and bored out to .010". The engine looks ok, except for the broken bellhousing. I knew this from the beginning. Didn't think that it was going to be a problem as I should have a few bellhousings laying around.
However, when I took the bellhousing off, I found that two bolt mounting connections on the block are cracked.
Is this going to be a huge problem now? Did I waste my time and money on this? Do I need the upper bolt connection? I think that the lower bolt connection area could be drilled all the way through in order to use a longer bolt. Can these areas be repaired? Pros/cons??
I am in need of help, desperately, as these engines are very hard to find (because they get scrapped), and it took me some time to find this one.
What can/should I do?????
Thanks, Ilya
Got it unloaded...
Thanks, Ilya
