Explorer
Down to rebuilding my 200ci. Keep in mind this is for a 66 Bronco with 4:10 gears. Total street build. I need to retain my vacuum for adding PB, and low to mid range torque. Thinking about an Isky #321256 256/256 cam, .450 lift, 202 duration, 112 lobe. I have a bare CI head and intake, 289 springs, double roller timing set, Duraspark 2, and Holley 350 cfm. It will be bored .030 over, zero decked. I need to make a decision to go with Keith Black flat top pistons or stock dished and how much to shave the head. I would like wind up with about 9.5 compression. With the .450 lift should I keep the 1.5 rockers or go to 1.6? Any suggestions along with expected HP/Torque numbers and power band would really help. I would like to take my parts to my builder next week. I really need to make a decision on this.
