engine/ radiator flush whats the best
az1966
gotta replace 2 year old radiator,, when I pulled the head to rebuild it ,,,the block looked like it had to much rust,,I've seen/heard/read that OXALIC acid is the chem to use and then flush with baking soda to neutralize it.....problem is I can;t find it so what would be the runner up for a solid engine flush? as usaul any info helps .. thanks
Oxalic acid can also be very poisonous. :shock:
Regular hydrochloric acid is cheap and will eat rust nicely. Even straight ethanoic acid (vinegar) will do the job.
Remember add water, THEN acid! Work prepared for a disaster. Wear chemical proof gloves, goggles and have a large pail of fresh water barely a yard away for emergencies.
