I am in the midst of rebuilding my girlfriend's (with her doing most of the work under my direction and occasional help - this is our way of bonding) new motor for her 1967 Mustang. This motor is a 200ci out of a 1978 Ford Fairmont. Although I have much mechanical experience with cars and a healthy collection of required tools, this is my first complete engine teardown. At the moment we're almost done disassembling it so I can have the local machine shop hot tank it to get the 30 years of built-up crap off the outside and clean what little stuff may be in the inside.
I have a couple questions:
Using this kit: http://classicinlines.com/proddetail.asp?prod=FEL-200-CGS do I receive enough freeze plugs to do the block only (including the rear ones) or does it also include enough freeze plugs to do the three on the head too? I'd love to pop the freeze plugs off the head to get it completely spotless inside and maybe to do some porting of the intake log while I'm in there but I don't want to break them out and then find I can't get replacements. If that kit doesn't include them does anyone know where I can get the correct ones? Might my local autoparts store be able to get me what I need? Should I go with this Felpro set or should I hold out for the Corteco set? What's the difference between the $10?
What are the advantages/disadvantages to steel freeze plugs versus brass?
Any tips on removing freeze plugs? I'd heard of drilling a hole in it and then inserting a screw and yanking them out, and I've also heard of just breaking them out with a hammer. Unless there's an issue with the technique I'll probably go with drilling a hole because it's less brutish.
The motor has 75,000 miles on it. Should I reuse the main bearings or buy new ones? A couple of the ones in the motor have some lines in them so I'm leaning towards just buying new ones. Is there anything I need to know when installing them? I already know to torque them down and to use assembly lube on all engine bearings upon reinstallation. What about connecting rod bearings? I haven't inspected those yet. Would it be good to replace them or can you typically reuse them if they're undamaged? Like I said, the motor was a healthy motor with 75,000 on it. We just want to make sure everything's gonna be completely kosher before it goes into the car. I don't want to replace them if I don't have to though because my girlfriend is on a tight budget and this project only moves as quick as she can afford to, so it'd be great to save money where we can. If it's one of those non-negotiable things though, we will.
We're gonna reuse the cam bearings (albeit with a new cam and lifters - we haven't decided what yet but something with a little more oomph that'll accentuate gofast parts as she can afford to install them) just because the removal tool is too expensive for me unless that's a huge mistake. They look pretty spotless to me.
Does anyone know the compression ratio for a '78 motor? I have a feeling it's probably around 8.5:1 but I don't want to trust my "gut" on such a thing. This is mostly idle curiousity. EDIT: I just looked on Classic Inlines tech info and found it to be 8.7:1. Will the use of the thin Felpro headgasket improve upon that at all?
Are there any tips I should know about/watch out for when reassembling this motor, or any motor in general? I intend on buying the Falcon Six Performance Handbook, but have not yet gotten to it unfortunately.
I feel like I wanted to ask more, but that's all I can remember at the moment. I appreciate any answers I receive.
