I bought a vacuum gauge so i could check for max vac on the carb. So the car is in park and the vacuum gauge read 18 Hg so i turned the screw until i got 20Hg and thought well that was easy.
So I got another person to sit in the car while i took some readings of the gauge, and i asked them to put it in Drive, and the gauge dropped down to 17Hg, and on the gauge it reads Late Ignition Timing. Well then, so thats my problem and question...
So is setting the timing the solution to my problem? Will turning the distributer fix it? I was gonna turn it, but where is the screw that hold it in place? But is this even the right way to fix it?
Neddle Readings:
Park: Steady; 20Hg
Park, Reving Engine: Fluctuates when step on to around 17Hg
Park, Steady Rev: Steady; 21-22Hg
Drive: Steady, 17Hg
Drive, Rev Steady: Steady; 20-22Hg
Thank you all very much who reply.
-Bryan
Neddle Readings:
Park: Steady; 20Hg
Drive: Steady, 17Hg
-Bryan
