MercuryMarc
The "choke" problem was really a cracked heat riser routing soot into the choke spring housing. That is all cleaned up, the heat riser tubes are plugged with high temp manifold repair putty, and an extrenal heat riser is now attached to the outside of the manifold. Since the temp is not as hot, the choke stays on longer but runs much better.
I went to purchase a replacement exhaust manifold and was told by a Falcon parts vendor that the manifold casting # of C8 means it was much bulkier than the 60-63 versions. He said the beefier versions are not reproduced.
I was hoping to get a new manifold, but will I have to repair my current one or find a decent used one? Does anyone have a source of a repro'd one that would fit?
The block casting is "C9DE" so it's a 69 200.
The exhaust manifold is "C8....." so it's a 68.
Thanks!
Marc in SF
63 Comet Ragtop, 69 200 six/C4 tranny, Pertronix ignition/Flame thrower coil, aluminum racing radiatior, temperature triggered electric fan, external tranny cooler, Fuzzy dice (Orange)
http://mercurycomet.net
Thanks!
Marc in SF
