My exhaust manifold gasket is leaking, again. I know what the problem is but I need a couple of you guys to look at their engines for me.
The front top hole in the head for the manifold bolt is not stripped but the threads are not as deep as they once where and the bolt does not hold as well as it should and it tends to work loose. I dont think thread locker will do the trick.
Here is where I need your help.
I am worried that if I try to drill the hole out bigger to put a helicoil in it, it will weaken that ear and break off completely.
I am thinking about threading a longer bolt thru and putting a nut on it but there is a very thin casting web in the way. Can a couple of you guys look at your heads for me see if this is on your head also?? If it is not then I will simply grind it out of the way and put the nut on. I am just worried about making the ear to weak. This is a bone stock '66 200.
