exhaust
mustangman33
im not sure on whether i should get a single or dual outlet exhaust. the duals look cool and from what ive been told sound better. but ive read that singles give more power. can i get a good sound out of a single outlet if i do 3 inch pipes? prob go with flowmaster.
Unless you've already done all the "other" stuff, single or dual won't make any difference. And the difference would be minimal at the seat of the pants anyway.
Sound is often better through dual pipes because each pipe is responsible for certain cylinders.
go dual out with no cross-over. you'll take advantage of the small six firing order.
3 inch is over kill and you'll lose ground clearance. also, a large single will give you a "jeep" sound.
