long story short. I got a 1981 Ford Fairmont 6-200 from a friend who was moving. It is a project I am putting back together just to drive for now (lacking funds to do more). It looks like he got as far as ripping out the emissions parts and leaving some other non emissions hoses unhooked. Detached parts are in boxes that are with the car.
So to make things simple/ cost effective I would rather not put anything emissions wise back on but I need some help. I don't know where some of this stuff goes. I am learning my way threw cars but I am not an expert.
CARB
I bought a Rebuilt Carter YF w/ electric choke from some recommendations. It did not come with any paper work so I dont know whats what. There are 5 "ports" on the carb. (bolted in place.. ) 3 on the passenger side (bottom to top 1,2,3), 1 is on the front of the car (4) and one on the drivers side (5):
Looking at a few manuals online I think #2 goes to the distributor?
As far as everything else, I don't know.
Vacuum Points
To make things simple I'll letter and number all the connection points:
Firewall TEE (A B C):
Intake Manifold TEE (where brake booster connects to manifold): D E F (I think they all are the same but just incase
* I am in need of this piece (Manifold Tee) along with the line & hose to the brake booster. Anyone who has this part for sale please let me know. The one I have is bent and wont take the booster line.
Hoses:
Trans modulator (6)
I was told this line coming from the transmission needs to go the vacuum source on the carb or manifold. Not sure where though.
2 hoses that come out of P/S Fender.
One says vapor (7). I was told to leave that one open. The other one ( 8 ) I was told may go to the vacuum tee on the firewall or get blocked off.
Hose Comming Out of A/C
Its not the Drain because thats lower down the firewall. No one has explained where this goes or what it does.
MISC
Lastly what do I do with the ports on the carb, intake/ firewall tee's that are not used block them?
I am having a bit of trouble getting the exhaust manifold out without a cherry picker. The one last bolt I need to get too is next to the A/C cube near the radiator. Any suggestions without disconnecting A/C?
The EGR to the manifold is on upside down and it looks like its blocking it off but would you suggest making a plate for it and using that instead?
I will wait to get these mile stones out of the way to worry about anything else. Thank you for your help. ~Frank Stupak
CARB
Vacuum Points
Hoses:
Trans modulator (6)
MISC
