I finally finished the fuel tank hookup and decided to fire up the Falcon yesterday for the first time in months. Prior to fueling up, I noticed the fuel gauge was reading half on a new, empty tank, so I started checking. Have a good ground on the tank, good continuity to the sending unit, gauge unit checks out, constant voltage regulator is feeding 12vdc to temp and fuel gauge. Aha! 8)
I swapped the CVR for a known good one, tested it to make sure, and put everything back together. Fuel gauge now reads empty - good. Off to the gas station and bring home 10 gallons which brings the gauge to about half. Voila!
I cranked her over in 5 - 7 second bursts to get fuel up to the carb, and then attempt to start. While priming the system, I notice my tach needle is bouncing when I release the key in the "run" position. Hmm, looks like the same frequency as the CVR. I press on thinking I may have to find out why it's affecting my tach.
Once I get fuel to the carb, I try to actually start the engine. It sputters a bit, then I finally get it to start only to have it die. Over and over and over again. This is really weird, it's acting like it's running out of gas. I check the carb and it is very wet, I pull the throttle, and get a strong jet of fuel from the accelerator pump. Hmm, maybe the needle is stuck (newly rebuilt Holley 1v), so I pull the bowl off to find there was definitely plenty of fuel and I can see the needle is not stuck. I play with the float a bit to satisfy myself that it isn't sticking, and it never fails to drop as it should. Hrmm.
While under the hood, I noticed a ticking sound, like a relay, coming from the distributor when the ignition was in "run" position. Sounds like the same frequency as the CVR. Damn.
I pull the instrument panel back out (what a PITA) and unplug the CVR. Tach needle stops bouncing and no ticking sound from the distributor. Ok, now it should run - not. Does the same thing, will fire for a few seconds, and then die. Only now I know it's not fuel, but ignition related. It acts like the key is being shut off.
I messed around with it for awhile and then gave up in disgust. I'm tempted to reinstall the old CVR and see if that makes a difference, it shouldn't but it's the only thing I changed since the last time I ran it. I suppose something may have "died" while it sat, but really doubt it.
I'll have to test the DII today, check coil voltage, grounds, and ??? Any ideas would be appreciated. I just know it's gonna be something simple. :roll:
