FLAMES!
hey guys! I installed this kit on my car that shoots flames...as you can see. I got 2 O2 sensors and welded them into the tailpipe, used a "hot box" and 2 coils to get spark to the plugs...It looks awesome, especially at night. It'll put fear into even the most hardcore ricer heart...
:twisted:
Hey man,
can you put up a list of what all it took to get the car to do that, and how to install it all??? I would LOVE to put those on my side pipes when I put the in.
Matt
I bought a kit off of ebay, just do a search for "flame thrower" or some variation. The kit says it is "complete" but all i could use was the "hot box" that basically acts as a dizzy for the coils to store voltage, then release. I went to a local muffler shop and a guy i know there had 2 O2 sensors that i then took to auto zone and matched thread with 2 spark plugs. Autozone also had ready made wires, so i bought 2 of the longest ones that they had that would connect one side to the coil and the other to the spark plug. The kit also comes with a relay, witched is the same as the fuel pump relay off of a 2000 Ford Taurus 3.0L It comes with directions, but because i have an MSD box i had to improvise. To shoot the flames, you rev the motor to 5000 or whatever, lower works but less size flames and shorter duration - then i click a button after activating the system that kill my ignition. I pump the accelerator to dump raw fuel into the exhaust pipes that then gets ignited on its way out. I then click the "ignition kill switch" off and the car spins back up to 5000 and i do it again.
let me know of anymore questions you may have
josh
Do you have a fully welded exhaust? Did you run a new vent tube for the tank towards the front of the car?
I am working on a system myself.
We're driving pre-Pintos so watch out. If you got hit in the rear, there wouldn't be just flames out the tail pipe but the whole rear end.
Andrew
:twisted:
I hope you have some "go" with that "show" or end up just like them. All show and no go.
LOL
db
