wouldent I half to cut the fire wall ?
What kind of mileage could I expect out of a 300 in a little scout with a Ford Toploader overdrive ford 9"limited slip 4.10 gears,
I would use a cam that runs 1000-3800 and up shift around 3000 rpm
the tires would be 33"x10"x15"rim
longer connecting rods 1:6 rocker ratio, 275 cfm carburater I would run lean advance the timming with a hot ignition system, run it on 92 octaine.
Basically a Scout body and chassie whith everything else ford...
The other truck I am considering is a 1985 F-250 4x4 ex cab 8 foot bed four speed manual whith same gearing and tranny as above
