Hi all,
I wonder if someone could help me read a plug. The Falcon had been running rough for a few weeks so I decided to put in some new plugs and see if that helped (and man did it ever!). The plug pictured below is from the #1 cylinder and the side that has the most buildup is toward the firewall. Not sure if that's intake or exhaust??
The plug in the #2 cylinder is about half as bad and the rest look pretty good with just a light, grey-brown haze. They all have a little black soot down in the deepest part but not near the tip. The only additive I have in is an oil detergent to help loosen a sticky lifter. With today's prices I've been putting in the lowest octane gas.
Anything to be concerned with? I will be pulling off the valve cover soon to paint it and was considering adjusting the hydraulic valves (if they do adjust??) Is there anything else I should be looking for?
Also, my distributer cap is really burnt up around the contacts, the side near the center. It looks like the plastic has melted away but not a smooth melt..kind of rough and granular. I'm running a Pertronix unit with a 40,000 volt coil so I ordered a new cap that is the highest of the 3 grades the parts store carrys. Hope this helps but just wondered if anyone has encountered this?
I don't know exactly how long I've had them in but it hasn't been nearly a year I don't think. I almost always make short trips. It's my daily driver and I only live 2 miles from work. Thanks in advance for any help.
