I have a 1961 Comet with a 68 200 six ,T5 Tranny , Summit HEI ignition , Headers , duel exhaust , Holley one barrel knockoff carb . The problem it will start and run perfect cold <I can drive for a mile or two , then will start to miss with no power and die . I can sit for a minute fire it up and drive some , then repeat . I thought vapor lock but will do it at 70 degrees . fuel pump new . tank clean ,gas filter clean .The metal fuel line has not been replaced is it posible to have small holes that suck air into the pump .? Lost mecanic say 5 different things . Any Ideas Thanks
