gague pod hook up
250mav
I wanted to hook up a gague pod to the engine, h2o temp, oil psi, volts combo but dont know where the sensors would go into the block if there is even a place. ive done gauges on a few GM v8's but the ford 6 is obviously a little diffrent.
hey thanks. if I get one of these 3 pod hook up's will it have the adaptors needed for a ford 6? Iam comming from the other camp (GM) so alot of this is new to me.
I think the adapters are a "universal" fit, and the sender itself threads into it.
I couldn't say for sure about the kit you're looking at, but my guess would be yes, but I have bought only temp guages off-the-shelf, and everything just fit.
I was just thinking when I bought the water temp kit for my chevy it had several abapters, only one worked with my chevy. once you get that in the manifold you screw in the sender inside the adapter. I guess if there was one for a chevy than there must be one for a ford.
