I am a novice at this and need some input from all the experience out there. What are the pros and cons of using aluminum, brass or copper versus steel or stainless steel for gas lines. I've heard of aluminum being used. Fittings are made from brass, so it probably could be used, but i don't know about copper.
Do you have to use a lubricant with any or all the metals when flaring? I would like to use brass tubing because it goes better with (looks wise) with the rest of the modifications to my 300 inline six. Any suggestions or comments will be accepted with gratitude.
Gene Johnson
Gene Johnson
