here's my delimar at moment which is better and make more hp or cost's less for the ford 6
iam leaning towards chain drive as you have less harmonics in the valve train and while not as accurate as timing gears the gears for a 2 peice set of gears is probly just as accurate when there is a thrid idler gear there.
other problem is the idler gear does tend to jam into the gears requairing extra force to turn then gears and cam.
advantage's for the gears should be more accurate in timing shouldent require as much to drive as the chain should.
if this was just a simple gear on gear case i whould say the gears easly whats your thoughts on this.
